1971 big block charger water pump housing help
dieseldazzle
3:03 AM
California
looked and looked on google images no help.
Putting a big block into a 71 charger that was originally a 318 car. I know later cars went to passenger side water pump housing outlet for the radiator hose. What about 71?
I ask because I want to use stock replacement radiator and accessories and don't want issues
Just a little tip.... make sure your timing marks on the timing chain cover & your harmonic balancer line up on the same side & aren't blocked by the lower radiator hose (ask me how I know)
Yup ran into that before I now always set timing cover and balancer on while I'm tdc the motor and degree the car in I also timing tape it then vht high temp satin clear over it
