I took a used but good rear bearing and honed it to be a slip fit for setting up. The wear difference between a used and a new one is very small and so far they've set up quiet. I'll check the depth with the new bearing and I never get more than .002" difference.Thanks.
I mailed Cass from DoctorDiff today and he advised me to change the clutches. I'm going to order it along with a rebuild kit for the 489 and add an additional inner pinion bearing to make the pinion depth adjustment a little easier.
