Windage tray?
Doba76
1:26 AM
Taber, Alberta
Possible silly question, just warning you all now! Do the later big blocks have a factory installed windage tray? I need to swap oil pans from my old 400 to the "new" one and in looking up the pan gasket, it says use 2 with windage tray. Thought I'd check before ordering.
That is correct.... you need one gasket below the windage tray & one gasket above the windage tray so the tray is "sandwiched" in between.
Gotcha, but the 400 doesn't have a windage tray from the factory, right?
