Rebuilding the dash harness
10:50 AM
Santa rosa California
After chasing several electric problems on my 67 charger I removed the dash harness so that I can find and repair all the problems with the connections wires and components at one time. Does anyone have a good source for the fuse block, circuit breakers, relays, and connectors?
I also found a 12g light green wire that is part of the body harness attached to the circuit breaker however I can't find it on the schematic does any one know what it is for?
After removing the dash harness, tracing everything out, replacing burned or corroded wires and terminals, I rewraped the harness and replaced the bulkhead connector with weatherpack plugs most of the electrical issues under the dash have been resolved. I still need to get the power pack replaced/rebuilt and replace the headlight relays.
I also found a 12g light green wire that is part of the body harness attached to the circuit breaker however I can't find it on the schematic does any one know what it is for?View attachment 388254
http://www.forbbodiesonly.com/moparforum/threads/rotating-headlight-relay-modification.135356/
