SOLD 68 A833
brian6pac
7:44 AM
n.e.ohio
I have I believe is a 1968 A833 on excellent shape, case has 8 - 16 cover has 2 - 16 then 8 23 spline input shaft, Came out of a 1968 dodge charger about 40 years ago.
$600.00 + shipping
if interested pm me
Has a Hurst shifter mount, I also have a Hurst shifter for it that needs shims # 6356 for $125
Is it an 18 spline or 23 spline?
I have I believe is a 1968 A833 on excellent shape case has 8 - 16 cover has 2 - 16 then 8 23 spline
$600.00 + shipping
if interested pm me
View attachment 388668 View attachment 388669 View attachment 388670 View attachment 388671 View attachment 388672 View attachment 388673 View attachment 388674 View attachment 389207
Is this an "A" OR "B" Body trans?
Thanks,Sam (in N/E Ohio)
Sorry I apparently didn't finish the ad, I came out of a 68 dodge charger and I believe it was original. I have had it for probably 40 years
Would you post the partial vin stamp on it? Curious on which Charger it came out of. A 383 by chance? Thanks.
Dan
There is a good picture of the side, it doesn't have a boss.
Interesting. The I thought all '68 A833 cases had a raised pad, stamped or not. Hmm....
Thanks.
Dan
Most likely...66/67 b body trans...check front bearing size
Ya after doing some research I guess it has to be a 66 or a 67 no way to tell, Unless some one can verify for me which year. According to Brewers web site 68 has a boss with the info stamped in.
Does it really matter if it came from a 66 or 67 as opposed to a 68? Aren't they the same? Asking because I may be interested.
