SOLD Need info
cheetah400m
6:25 AM
Omaha
Feedback: 6 / 0 / 0
My '66 satellite two door hardtop is missing the front exterior windshield trim. I found a gentleman that has a set off a four door. Will his exterior windshield trim fit my two door hardtop?
Thanks folks,
Bob
good question , try and see if the windshield is the same part number for 2 and 4 door , then it should
good luck
You may try the tech section under the 66-70 models instead of the sales area. you may get better responses to your question
The side pieces for the 4D will be slightly too long.
A good saw, a steady hand should make them work.
Btm will,,,, top won't,,,It has a different curve to it for the 4 dr. larger windshield.
