Dana 53?
BudW
11:07 AM
Oklahoma City
I was looking in my ’67 Dodge FSM (Factory Service Manual) and ran across this in the propeller shaft section.
I noticed three different propeller shaft lengths (for the Dodge B-body) for 4-speeds:
383 w/8-3/4” (blue arrow) 52.03”
426 w/9-3/4” (red arrow) 50.90”
440 w/9-1/4” (orange arrow) 51.81” (which also is same length for 426, 440 automatic with 8-3/4”).
That got me wondering about the 9-1/4” differential (My Question #1).
It also made me wonder why driveshaft lengths are different between them (My Question #2).
Then, I went to differential section of same book and took these two pictures.
Google research led me to http://www.forcbodiesonly.com/mopar-forum
Where I found out the 9-1/4” is actually a Dana 53 (also used in older Jeeps).
C-bodies used the Dana 53 in ’67-68 (only) behind 440 HP 4-speeds (only).
It appears (from what I can read about), the same Dana 53 was also used in ’67 (and maybe ’68’s ???) B-bodies with 440 4-speeds, whereas the 426 4-speed cars got the Dana 60.
Is this correct? (My Question #1).
Has anyone ever ran across a 9-1/4” in a ’67 B-body (or in ’68) (My Question 1a)?
Further looking into my ’67 C-body FSM, I ran across this:
Note: the driveshaft length are all the same.
Also in my ’67 parts manual
A 3.31 to 1 ratio - an odd ratio for Chrysler
Other than axles sharing the same as their 8-3/4” counterpart, it doesn’t appear anything else interchanges between the Dana 53 and Dana 60.
Link to Dana 53 in a C-body http://www.forcbodiesonly.com/mopar-forum/threads/68-440-4-speed-rear-end.23307/
(A picture from the above link)
A Dana 60 (pic swiped from internet)
The Dana 53’s has been confirmed in C-bodies and it appears should also be in B-bodies (and no, not the 9-1/4” corporate axle version).
Now, onto my question #2.
According to my ’67 C-body FSM and my ’67 parts manual, the propeller shaft length is the same between 8-3/4” and Dana 53.
Why is it not the same length between same on B-body (Auto or 4-speed as well as 8-3/4” and 9-1/4”)? (My Question #2).
BudW
My 67 Fury [440/4-speed]had one. It was smaller than a 60....and not the 9 1/4[corporate] everybody is familiar with.
I've had several in Full size wagons and C Body sedans and hardtops.
I’m not debating the C-body Dana 53 (it’s well established).
I’m wondering a Dana 53 was ever factory installed in a B-body (’67 440 4speed, or maybe even a ’68, to be exact).
I’ve seen a few ’67 & 68 B-body 440 4 speed cars and seen they had “a Dana” in them – but never knew there “might have been” two different Dana possibility’s.
I know once I did see a "Dana", I don't look any further (or at least before now).
It could have been a FSM error, or it was planned to use a Dana 53, but last minute change not to use it – IDK.
BudW
BudW
I would imagine that the 8.75, since it was plentiful was used in lieu of the Dana 53 in B bodies. Only time I saw the 53 was in 4 speed C bodies and one in a full size wagon that came with a 4 speed.
Hey that's my 60 and garage floor!
Perches are welded, should be installed this week.
PS please PM me for address to send royalty payments. :D
I'm jealous – for that is a mighty fine looking differential you have there.
If you want, I can take the picture down?
The only Dana I’ve ever owned is a Dana 80, that’s in my Diesel pickup – which I think it weighs in as much as what one of today’s jelly beans total weight, is (excluding driver) . . .
"I'm jealous – for that is a mighty fine looking differential you have there.
The only Dana I’ve ever owned is a Dana 80, that’s in my Diesel pickup – which I think it weighs in as much as what one of today’s jelly beans total weight, is (excluding driver) . . ."
Thanks, my diff is just a little above average but I'm not ashamed.
You can leave the pic up.
Your Dana 80 is impressive, but really, how many cars can you actually fit it in?:rolleyes:
. . . but really, how many cars can you actually fit it in?:rolleyes:
I think the question should be: How many of today’s cars, could my Dana 80 make, if melted down?
Each of my rear brake drums weight as much as I do.
Getting back to Dana 53’s in ’67 (or ’68) B-bodies ???
I believe the 53 was only made in the 67-68 C body width. The 53 isnt near as beefy as a 60. It's been a while but, I recall it being closer to a 44 in strength. Other than being an oddity, hardky an upgrade from an 8 3/4. IMO
In addition- you are right though. Personally I could look at a 53 under a B body and just assume it was a 60 without a second glance.
The Dana 53 was also used in 1956 Packards, 1949 to 65 Lincolns, and 1957 Mercury.
Corrections (in red):
The Dana 53 was also used in several Jeep models, 1956 Packards, 1949 to 65 Lincolns, 1957 Mercury, 1967-68 C-bodies with 440 4-speeds and maybe (not sure yet) 1967-68 B-bodies with 440 4-speeds.
This one supposedly came out of a 66 Satellite,no reason to doubt the fellow I got it from,3.31 sure grip,bolted right into my 62 Savoy wagon,no need to change anything.
