1967 coronet drag radial question
Reamzer
12:25 PM
Arizona
What would be the right size drag radial for a 1967 coronet with a 3.23 rear end?
727 trans. 440 big block, low compression motor. Mild cam, 750 carb, headers intake. No idea on hp range just know she's got a lot of torque!
What's kind of power is the motor making? 727 trans?
Only radial sizes I've found are either 225/50/15s which seem to narrow. Would 255/60/15s work good?
255/60s will be about the max you can fit into a 67 wheel well. With a 3.54 gear, it should make for a good mild HotRod.
