Charger Roadrunner seats the same?
max340
1:24 PM
San Diego
Are the rear bench seats the same for 68-70 Chargers, Roadrunners, satellites, and coronets? Thanks, Tyler
Seats will be the same, the tracks for the Plymouth b bodies of those years all interchange, though I'm not certain that they will with the dodges.
Kinda what I thought. Thanks garrett1308
Here's the fix. Go to Harbor Freight Tools, buy one of their wire welder sets for $100, and watch some youtube videos to learn how to use it. Then get whatever seat tracks you can, and if they don't fit measure the floor pan holes, cut one of the mounting pegs off the tracks and weld it in the right distance away. Problem solved without having to spend $$$$ on specific tracks and you can weld lots of other stuff. :)
Thanks Bruzilla but I'm referring to the back seats.
The back back seat is slightly different from an 8 to 9. The clips to secure it are in a different spot. I have a 69 seat for my rr but it needs redone. I swapped it for a 68 for the time being, because of difference it doesn't fit quite the same.
Oops, I read it as front seat, ignore what I said and listen to hemi gts
