miller
Exactly like khryslerkid, and others, said. For someone not experienced on these motors, and the valve train, it can be a little confusing. Just takes time. Don't try to read too much into it all, until you get used to what to look for. Just like me mentioning the push rods, that's just one possible source for 'engine noises'. Simple...look for the obvious, and go from there.
How many miles on the motor, will help. Your plugs...with the oiling on 'em, could be getting past the rings, or valve guide seals. Depends on how bad, decides what to do about it.
But, your asking about a 'tick', that's probably somewhere in the valve train. For any given valve, push rod, tappet, or cam lobe, each one can only be looked at right, when the tappet is down, on the heel of the cam lobe.
Look over the cam itself, each lobe, for any wear. As said, at the tappet, for correct pre-load. For a bent push rod, on and on...
Can also not be worth worrying about, unless it starts getting worst. Too many things can happen on these things, just like any other motor.
