SOLD 4 barrel intake manifold wanted
dennis degeneffe
1:17 PM
green bay wisconsin
I have a 1965 Belvedere, it has the original 273 2bbl and automatic transmission. i am looking for a 4bbl intake, casting number 2465726 or Edlebrock d4b. If you have a carb and a set of headers for this set up, I would be interested in them as well.
I live in Green Bay Wisconsin
thank you
ya hey, dere! welcome to FBBO from a FIB.
hit up the welcome wagon and introduce yourself when ya have a chance...
and good luck on your search...
thank you
I think you mean LD4B don't you?
From my understanding/research, ld4b was for 1966 and later small blocks. d4b was for 1964,1965 because of the angle of intake to head bolts. Please correct me if I am wrong
You sure might be right, I was under the impression that the 273 motors were the same for each year. But I'm no small block expert.
64 & 65 use 5/16" bolts, 66 & up use 3/8" bolts.....and they are at different angles as well
there were 2 different cast iron intakes from the factory as well....one for the early engines, one for the late style
I can look up the number later tomorrow if you need.
Check over at FABO.they come up regularly
The 65 4 barrel intake part number is
#2465727. The casting number is #2465726. This intake was a 1 year only part for the 273's and will only fit the 64 and 65 heads. As mentioned, in 66 the bolt size and angle changed to the more common 318,340,360 configuration.
Dennis,
I found it.
Conversation started.
