Jung
Wondered if I might ask the collective's advice on some problems I'm having? I'm running a not too aggressive lift Comp Cam hydraulic roller pushing Harland Sharp Rockers in an Indy EZ headed, 505 stroker RB. Within less than 400 miles of getting the engine running, I experienced a big loss of power over 4k and rough running. I've recently had a chance to tear down the top end and it seems like all the lifters failed. The heads of the adjusters have been hammered flat and the rollers for the valve tips no longer spin freely. The adjusters settings vary wildy on both sides, some screwed in almost below the locknut, others with barely a thread showing underneath. There is no similarity for any of the cylinders, they are all different. Seems like whoever put it together had a hell of a time setting the lash and didn't spot an underlying problem with bad lifters? Anyone had a similar problem?
