FOR SALE 489 Center Section 3.23 Sure Grip
nstyle73
4:42 AM
Illinois
Feedback: 5 / 0 / 0
This is a center section from a donor car that I purchased. 489 case, 3.23 Sure Grip. The gears are date coded 8-21-70 and were removed from a '71 so I believe these to be the original gears and Sure Grip. The car was a roller and I never drove it before sourcing the parts I needed. Pinion snubber threads are good as are the U-joint retainer bolt threads. 7290 Yoke (2 5/8" Inside, 1 1/8" caps) Gears turn freely and there appears to be no damage to any of the teeth. Asking $400 plus shipping from 62420
IMG_0966.JPG IMG_0967.JPG IMG_0968.JPG IMG_0969.JPG IMG_0970.JPG IMG_0971.JPG
View attachment 411344 View attachment 411350 View attachment 411351 View attachment 411354 View attachment 411356 View attachment 411357
cone or clutch?
Yes cone as stated above for all of those reasons. I do not know of a good way to test without actually installing in a car or disassembling.
You can actually clamp an axle in a vice, slip the diff on, stick an axle on the top side and reef it around with a pipe wrench. It should turn pretty hard.
I had read about the axles, but did not know exactly what result to expect when I turned it. I Will try tomorrow.
