My 727 is Done
Canyon707
7:15 PM
Napa
Just put it in the car this morning and fired it up. There isn't much more good stuff I can have done to it. I guess time will tell. I think its good.
What do you have in it that's not stock?
Pretty much everything. Billet pump billet drum, new clutches, billet input shaft, I have a box of parts that I guess are now junk.
Congrats! Just curious what do you think you have in it vs buying a race prepped unit?
I guess but, I don't think it's worth much.
Maybe not much,but a few sheckles will put some fuel in your tank.I'm to the point were I want to build another trans and sell it.I also have 2 more PB cases as backups!
There not to far apart all the parts are race parts. I think it ran about 2500.00 total. I removed and he installed it and tested it. It now is all about l
I still run these stock parts:
input/output shafts, 3 pin planet carriers, pump, servos. The stock front planet carrier, sunshell, governer housing, and reaction shaft are stock parts I modified. Both drums and rear clutch carrier are aluminum.The only failure has been the front planet splines, once in 380 passes. If I fail another front planet carrier I'll upgrade it.
