SOLD 11" drums and backing plates
1967coronet440
6:23 PM
Indiana
Feedback: +21 / =0 / -0
I have a set of 11" drums with backing plates off my 8 3/4 worked fine when I pulled them but switched to disc, just need to be cleaned up a bit, can send additional photos upon request $150.00obo plus shipping. Located in northwest Indiana
With the backing plate laid face down on a flat surface, what is the depth from bench to top of flange?
I believe they are the 11 x 2.5
If that helps
I Could get you a measurement tomorrow when I get back to the shop.
Shoe width and the backing plate depth would be great info....
Great info. Thanks for the effort.
Actually what you have there is
a 11x 2 1/2 drum, as the drum width is right at 3" but if you notice, the swept area will measure 2 1/2" which is correct as the shoes have 1/4" clearance on both sides. Very typical of common 11" rear brakes
I want to acknowledge that you did describe these initially as 11 x 2 1/2 brakes, and thanks again for the measurements....
