- 10:58 PM
- Feb 20, 2012
- New Hampster
I installed a new cam, timing gears & chain in the 440 last evening. The crank gear has 3 keyway slots & I lined up the "0" with the punch mark on the cam gear. No problem there. Put the timing cover on but when I put the balancer on on, the timing mark was a couple inches off from the TDC mark on the cover. It's been a while since I did a cam job and I just want to check with the experts here to see if this sounds right or not.
Below is a picture of the old gear with the 0 mark that I lined up with the cam dot....
