bigmanjbmopar
Newb with a view
There is a +5 vdc signal (voltage) to all the guages and the fuel sending unit is basically a resistor and as the arm moves back and forth that changes the voltage of the 5 volts increasing or decreasing that is what you see on the actual gauge. if the wire that goes out to the sending unit is worn out or corroded it will raise the resistance or in some cases lower the resistance causing a no read or low read etc. that's why people say get a new piece of wire and run it from the gauge to the unit and then try it. oem gauges were very slow in reading fas changes to the sending unit arm so don't expect it to read fast.
