I need this tool.
BeeKool
9:14 AM
Iowa
I need a 3/8" coupler to connect my ratchet to my distributor wrench.
I had one but it ran away. I got it from an estate auction so I'm not sure where to get another.
It should be no more than an inch or so long. Also I would like to get more sizes of the distributor wrench if anybody can point me in the proper direction, thanks
A twelve point socket should fit both ends if you get the right size. The twelve points will fit a square bolt or square drive on a ratchet. Then just plug the other end into your distributor wrench. You probably already have a socket that will work in your tool box!
That's a good idea. But the part I had was double 3/8 female and knurled nicely on the outside.
Now that you mention it. I have some old 8 pt sockets that would work.
I was hoping to replace the part though
cut it off and weld on the correct female drive adapter.
How about take a socket for a square head nut, in the appropriate size? ...........................MO
I ended up ordering the kit from Summit. It was a carbon copy of the one I lost.
I initially wanted to order the kit from K-D because it looks to be of higher quality, but the bastards wanted 20$ to ship it to me. As opposed to the 6$ from Summit.
Thanks to all for the speedy response.
Ordered Sunday got today at noonish.
Total cost $15..
