Well, today was a fun time. Just kidding. I don't have the benefit of a hoist, nor a lot of wiggle room in the shop, so it was a real joy, crawling around underneath the X, disconnecting remaining tranny linkage, header collector gaskets and the PS motor mount, to allow for my initial plan, that being to simply lift the engine on the one side to create enough clearance to remove the damn PS header. Turns out - the plan worked np. Once the header was dropped out of the way, I had easy access to the bottom row of header bolts. Removal of the head was straight forward. Close examination of the block surrounding bolt #8 (shown earlier) including the surrounding head gasket, showed no obvious signs of damage. I am left to conclude the oil (under pressure) was travelling up the head bolt threads. The sealant I had used on the head bolt threads had obviously degenerated to little more than a slimy gumbo and was good for squat. I swabbed out the bolt holes, and there is an obvious presence of OIL in the bottom of the bolt holes, so I am also left to conclude, the lower row of head bolts - enter into oil galleys, and thus require a quality sealant. Any suggestions?
Or, am I wrong - and the presence of oil within the lower row of head bolt holes - is in fact a bad thing? Hopefully Not !!!
Btw... I also noticed when removing the distributor, the earlier ground shaking backfire, had also blown out a portion of the distributor-to-block gasket. It's just as well, I pulled this side of motor apart, or I wouldn't have noticed this until later on. Over the years, I've had backfires from time to time when dealing with problematic hot start issues, having put a little gas down the carb to get er fired up, but I've never had all these problems arise from doing so. Always a first time, I suppose and most certainly not the type of subsequent issues, I want to deal with again. I'm hoping the new Holley 750 Ultra Double Pumper and Heat Shield, will go a long way, to resolving the hot start issues, once this is all buttoned up again.
So, unless I discover more issues... I gotta score: a new head gasket; quality thread sealant; an exhaust gasket; and 1 intake manifold gasket kit - before I can bolt 'er all back up again and then see what happens...
After going to all the extra trouble of tearing down the motor, it's nice to know, that no underlying serious damage, appears, to have been done. To me, it now looks like a simple failure of poor thread sealant. If true, removing/cleaning & re-sealing the lower head bolts (one at a time) would likely have corrected the leak. It's better to have been safe than sorry, I suppose - by doing all this extra work. Thankfully, I didn't have to pull the motor.
I also noticed that spark plugs were loose. Not sure why. I may have forgotten to retighten them, following the initial install, which certainly didn't help
me any in maintaining proper compression, given the carbon build up. That, and she was running a little rich, I suspect. Hummm - Also time for a good
tune up. lol
