Mike Gaines
- 2:46 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I am leaving for Famoso tomorrow am for the Summit Series Race Sat/Sun Jun 3 and 4.
Will be the first outing with my new MAX WEDGE Heads (were STANDARD PORT up until now) that also have had some port work done on them. No flow bench but probably flow around 325 or so. Also now have a genuine INDY DOMINATOR MAX WEDGE SINGLE PLANE INTAKE MANIFOLD (it was an Edelbrock standard port 440 single plane intake manifold before with a 4150 to 4500 Dominator adapter).
Air will probably be around 3000' adjusted altitude because temp is forecasted be 99 to 102 degrees on Sat/Sun
My old combo (as stated above) would run between 10.60 and 10.65 at 124.5 to 125 mph at 3000' adj altitude. (this old setup ran 10.48 at 750' adjusted altitude)
My setup will be exactly the same this weekend as far as everything else goes except for the new heads and intake...so it will be an apples to apples comparison.
So....Hoping for low 10.40's which would be about a 2/10th lower ET with the new heads and intake....
I will report the results.
