Dragon Slayer
I am rebuilding a 1969 Carter 4620 AFB. I have the technical document that list part numbers so I could compare installed parts against the technical sheet.
The problem I have is the pump side secondary venture is not the part number correct piece. It is a 348 which I believe would have been on the 66-67 equivalent AFB car.
So here is the problem, the Opposite pump side venturi is unique in design, and does not have the initial discharge port inside the venturi triggered by the air valve. The 348 does, but it has different hole design.
Did carter move away from an initial discharge port on the secondary, or is my part number correct version a defect?
Does someone have pictures from a carb restoration to show original 4620 secondary venturis?
I have seen several AFB secondary's from various years that have different configurations, but this 4620 seem unique. I have attached some pictures for comparison. The first is the base, which has an extra hole closer to the airvalve that most other AFBs do not have. The original venturi is on left with 2 tubes, the others are different versions. The original is on the right, in the later pictures when I show the initial discharge port on the venturi. Thanks,
