Front disc brake lines.
Brandy
Jack Stand Racer #6..and proud of it!
1:14 PM
Salisbury, Vermont
Who sells pre made front disc brake lines for a 67 Coronet with 76 Aspen front disc brakes?
Thanks everyone. Ghost.
I'd call Dr Diff for advice.
My only advice is to avoid InLine Tube.
I have both success and grief with them. Not great odds if your vehicle is not 5 years old or less. Did you mean to say drum 67 lines for the front , and shorten them? I suppose I could do that and set up a bracket to accept the disc hose and C clip.
Thanks!
I don't want to get off topic, but what's up with InLine Tube?
InLine Tube penalizes you if you buy from their eBay store. You are exempt from any customer support other than email communications through eBay. It is not any cheaper to buy through the eBay store; I bought through eBay because I had quite a few gift cards from Christmas.
My order arrived incomplete. Called InLine Tube and was told that eBay orders are only supported through eBay email. This took 2 full weeks to get replacements (please send pictures of your parts, explain if the box was damaged, or opened, etc). Fine. Everyone makes mistakes.
Installed the lines. Fitment was so so in some areas.
Then I fought one line leaking for another two weekends of frustration. Back to the game of support through eBay email (send a picture of the line that is leaking, etc). Did not get a response for 10 days!
I finally threw in the towel and hired a mechanic to come to my house ($45/hour). Seems the problematic line had a off center flare. He fabricated a new line using his (very nice, professional) brake line machine.
Then fought other seeping leaks. My mechanic did a 'last ditch effort' and tightened the lines until the tube nuts were damaged. Leaks have stopped, but these lines will never be removed again. My mechanic (a former Porsche/BMW mechanic who is now a mechanical engineer I work with and in process of a 1966 Chevelle resto) thinks the quality was mediocre at best of InLine products.
The eBay feedback for InLine tube reflects my experience. Negative feedback averages about 5 to 7 people per month. They have a 99.1% positive rating, so I am in that 0.9%, and I will make certain people hear my story.
If I ever have to do this again I'll fabricate my own lines. The line my mechanic fabricated did not leak with just a single torque of the tube nut.
Ghost their was a few 67 bodies built with disc brakes. Also the 68 car brake line piece can be used. You will have to make modifications. Also consider longer hoses if you are looking to do this..
Just use the rubber hoses from the Aspen they are just fine I just removed that whole set up on my 67 x I put the original 4 piston set up back on the car
Thank you for the tip, I appreciate that. Don't often see a guy who has an Aspen or the set up, on a 67. Good info!.
No problem it seems that some of the old mopar guys have been doing this before they made those kits mine were on my car when I bought it 26 years ago
I picked up a set from a local guy who builds and collects. He's had them sitting around his shop for years and I bought them. The rotors and calipers were shot but the spindles are fine. Parts are cheap too. Was not sure if the standard flex hose for the Aspen would be long enough. I have to either make my own steel lines or modify some that are long enough though. The master cylinder is under the dash.
The line going across to the right side will go up under the dash and down and out through the floor and over the frame to the Banjo bracket. The left will do the same.
i just did the conversion to my Belvedere used the '82 diplomat master disc and rear diff wth the 11 inch brakes. for the hoses i used gm brake hoses from a camaro or something and then modified the banjo end
on the grinder and put them on . i go take a pic and post it after
i think i used
H73305 in doorman ,
Looks like Dr Diff will be the one if I decide not to do it myself. They have a very easy to use selector and many options. Thanks.
Dr Diff will reply by email. Always within the day, and sometimes within the hour. I liked his support.
The Aspen or duster rubber hoses look just like the factory installed them Why not get the front steel line kit much easier than fighting use the original steel lines for the car fit right look right cheap and easy
You can get just the front line kit for the belvedere or satellite
