ibsorgn
Hello,
I have a 72 Satellite that I installed a line lock on the front disc brakes. I installed it before the distribution/proportioning block. After installing I found the instructions and to my surprise it read that the LL should be installed after the d/p block. I don't understand the logic but I've found that the LL does not like to release but yet I hear the solenoid click. Even with the power disconnected the LL will hold the brakes. I'm wondering whether the LL is defective or the proportioning valve is causing something to happen. Only way I can release the brakes is to loosen the brake line from the master cylinder to release the pressure. Any ideas out there as to what is going on.
