oil fill Hemi
Beavis
10:23 PM
Berkshires
on the 1969 Hemi roadrunner, which side is the oil fill on? i see some cars with it on the driver side some on the passenger side ?????????
Both sides. If you have stock covers there is left and right, sparkplug wire holders determine l/r.
I understand both sides work, but how did it come from the factory ??
66 to 69 valve covers are the same. The 70/71 valve covers only fill on passenger side and have rubber grommets for oil and PVC. As I said before there is a left and right because of spark plug wire mounts.
The oil filler cap will be located on the driver side valve cover. The PCV unit will be located on the passenger side cover.
