Wietse
Hey all,
Since i own the car i noticed how the selector indicator on my steering column always has been a bit "off".
This is actually a little clip that can be removed but there is no real adjustments possible.
2 Days ago i had to pull the steering wheel to replace my indication cancelling cam is it was broken.
After reinstalling everything (also had the 2 nut removed that secure the assembly on the column to get some access to the wiring for soldering) the car will not start in P position, when selecting N it will start.
Now the indicator is more off and actually showing N while in Drive so i need to see how the set this properly again as this is kinda confusing now and does not look good.
I checked the manual but only found some regarding the manual gearbox adjustment.
Not really sure where to start with this, any suggestions/tips?
This is for a '69 Coronet, 727 tranny.
