cr8crshr
- 6:54 AM
- Feb 13, 2009
- Northwest Nevada
FOUND THE BRACKETS!!!!
I am re-offering up for sale a ScareBird Front Disc Brake set up with a pic of the parts sheet for compatible parts. I somehow wound up with these as well as the set up on my '66 Plymouth Satellite. It's a very good system and has been very reliable for me. I just do not need these it so they have to go. It allows you to use your existing brake spindles over getting the correct disc brake ones.
Change out your inadequate front drums for affordable disc with our US-made. These cold-rolled steel adapters bolt straight on to your drum spindles- no matching is necessary to the spindle, nor any realignment. But I do recommend that you do an alignment anyway to insure correct alignment. You can use Lincoln rear rotors (10-1/2", same wheel bolt pattern) and 1990 Chevrolet Celebrity calipers. This is specifically designed to clear your OEM 14" rims. This is a medium duty setup as the rim constricts how big of a rotor/caliper combination will fit - so if you are running a 440 or Hemi you may want to step up to 15" wheels and our heavy duty setup. The Heavy Duity setup is also available on their web site.
Everything is available through any parts store and actually is a less expensive way to upgrade from manual/powered drum brakes to a disc set up. Now for the fun part...The rotors and mounting brackets which have the correct bushings already installed, are being offered for...$75.00 plus shipping and handling to your door. They are weighty but I will do my best to ship as inexpensively as possible. I prefer Pay Pal but will accept USPS Money Orders, Bank/Cashier's Check, and of course your personal check. The latter will have to clear the bank before I will ship. Absolutely no Western Union Money Grams. I am getting out of the hobby so I need all of my spare parts gone as I am putting the proceeds towards my new house and its projects...cr8crshr/Tuck
Pics 1221 - 1227 are what I have. Pic 1228 is a pic of the finished look. Pic 1229 is the heavy duty set up that ScareBird offers. Pics 1230 - 1231 are the compatible parts available through say Rock Auto, or any other parts store.
