dvw
Though there is a solid sleeve availible for the 489, it normally uses a crush sleeve .Not correct. The crush sleeve is a quick way for the factory to set bearing preload. Pinion depth in the 89 is still set by the use of a shim just like it is for the others. The bearing preload uses shims in the 42 and the 41 cases......
