FOR SALE 1968 B Body non rallye non A/C dash parting out
'68 Charger
7:04 AM
Akron, Ohio
Feedback: +80 / =0 / -0
Complete green dash removed from a 1968 Dodge Coronet 440 model.
Dash is completely disassembled and parts have been cleaned.
Prices: (shipping from Las Vegas, NV not included in the price)
Am radio core for rebuild, powers up and radio dial light works. Pre-sets work, tuning works - but still needs attention because it doesn't pull in the channels. $50.00
AM radio plate, no hacks, no cracks $75.00
Glove box bezel "Hockey Stick" no cracks $50.00
Driver's side end bezel, slight warpage $20.00
A/C block off bezels are broken
Ash tray SOLD
Standard cluster (sweep) untested $100.00
Switch panel & switches (lights/flashers/2 speed wiper/washer/dimmer untested) $150.00
A/C center vent block off plate (plastic) $40.00
Glove box latch(loop style) $20.00
Glove box door (no rips) w/latch (no key) $50.00
Glove box hinge $30.00
Heater control panel (selector slider knob broken) $80.00
Heater temp control slider cable, no kinks $25.00
Selector slider cable, no kinks $25.00
Long side-to-side trim piece, no dings/scratches/bends (needs black paint touch-up) $75.00
End cap curved trim pieces (RH & LH) $40.00
Metal dash frame non A/C bare shell, no VIN tag $125.00
Steering column cover plate $25.00
Defrost vents, NO broken studs $40.00 (pair)
Main center dash pad, one small defect in the ashtray cutout $100.00
Ignition switch w/bezel (no key) $50.00
Map light delete plate $20.00
Fuse block $20.00
Note: top speaker is being sold in another grouping (not shown here)
Old school under dash 8 track unit $5.00
Plus OEM hardware bagged & tagged upon removal of each item (ask for prices)
More pics upon request.
s-l1600x2.jpg s-l1600x22.jpg 20170531_181816.jpg 20170531_181819.jpg 20170531_181822.jpg 20170531_181825.jpg 20170531_181827.jpg 20170531_181830.jpg 20170531_163618.jpg 20170620_053449.jpg
Defrost vents (green), NO broken studs close up pics.........
Price drop $30.00 (pair) + shipping
zevjivvrgivk001.jpg zevjivvrgivk002.jpg zevjivvrgivk003.jpg zevjivvrgivk004.jpg
Reduced to $125.00
20170727_032627.jpg 20170727_032555.jpg 20170727_032600.jpg 20170727_032607.jpg 20170727_032611.jpg
I need a glove box light , the push pin door switch, and wiring back to tbe main harness, if available. Thanks
Okay now I think I know what you're talking about (see red circle in 1st pick).
And if so I attached pics (one pic each of each side). They both have broken pieces, the LH bezel could maybe pass for a driver car but the RH bezel is toast.
