DrewTX
I'm curious what you guys do for theft deterrent. I guess you could say I'm a bit paranoid, but for good reason as these are pretty easy cars to steal. Most stolen here in Texas go south of the border. I have an Earl's fuel line shut off valve, battery disconnect hidden in the wheel well, and an NRG quick disconnect steering wheel with a quick lock hub. The removable steering wheel is way cool! All are kind of a pain as they require reaching into the wheel well or pulling off the steering wheel (not a lot of work). I plan adding a hidden toggle switch to the negative relay I have wired to my coil, so it wouldn't start when not grounded through the switch. This way I would have only one wire going to the switch, the other toggle terminal grounded under the dash. Is this a bad idea? Any better ideas on this? I'm so done with alarms.
