DAVID A HILL
New Member
71 roadrunner 383 automatic.  both original exhaust manifolds are broken.    should I replace them with manifolds or headers?
			See, this is an example of how several people can have the same information yet still come to opposite conclusions.Seems to me that headers have more square inches of surface area, and that headers will throw off heat quicker. therefore making more heat under the hood. Cast iron exhaust manifolds contain the heat with-in them and more heat goes out the exhaust pipe. I believe headers are mostly beneficial at higher RPM. ...Anyway, that's my story and I am sticking to it ! ........................MO
More heat? Logic tells me that a less restrictive exhaust system would run cooler.
Headers for a stock 383 make about a 18-22 HP difference. Cars with headers do not have to be louder than a car with manifolds either...Manifolds often give a deeper sound with more interior resonance than headers. Thin wall headers do sound more "tinny" and hollow. I still like the sound. Good headers seal well. My TTI headers only get new gaskets when I have pulled the engine.
I have had headers on several cars that had manifolds when I first bought them. The only bad experiences I've had were with CHEAP headers.
Kern Dog , you are wrong because Mark Worman ( Graveyard Cars ) says so. And he knows more than anyone. ..................(a little sarcasm in case you didn't know) I didn't put headers on my 440 because good ones are very expensive , especially ceramic coated. My past experience was loose header bolts, and leaking gaskets. And I don't like the sound. And, I am a rebel among my peers. Only thing I like is that on well designed headers, the spark plugs may be easier to get to. The 68-69 magnum exhaust manifolds are a bugger to get to the plugs.........................MOSee, this is an example of how several people can have the same information yet still come to opposite conclusions.
Theoretically, What do you think retains more heat: A solid block of iron or thin sheet metal?
Restrictive exhaust systems RETAIN more heat because the exhaust faces more backpressure on the way to the tailpipe exit. Did you know that exhaust pipes are hottest at the points where they have the most restriction?
Hey, have all of the opinions that you want....Dyno tests prove that headers add power and not just at high RPM. First, they flow better, allowing an engine to get even MORE fuel and air in. Secondly, they scavenge the cylinders, in other words, one exhaust pulse sucks the next one out.
Thicker metal verses sheet metal. Just for sake of argument, thicker metal will retain heat for a longer period of time, but may not throw off as much heat as thinner metal. I can't speak from experience, but a lot of people that do have the experience, claim headers do make more engine compartment heat. I think I will go with the most prevalent opinion.....................MOSee, this is an example of how several people can have the same information yet still come to opposite conclusions.
