I took this from a older NHRA rule book. I believe this rule still stands.
13.99 1/4-mile (8.59 1/8-mile) or quicker:
-A driveshaft safety loop is required when you run slicks (not drag radials or street tires). With street tires or drag radials, no loop is required until 11.49 1/4-mile (7.35 1/8-mile) and faster.
I put one of these loops on both my cars. No drilling required. Bolts to the trans cross member.
http://www.manciniracing.com/mabebofrdrsh.html
If you're using SlicksGenerally required with sticky tires or slicks. However local track rules may require it at a certain ET level, 13 seconds or quicker.
a front drive shaft safety loop @ min.Check Summit Racing. A good investment at any price.where are the $25 drive shaft loops at?
any links?
thanks,
watermelon
The exact same thing happened to me. Spit half the driveshaft out going through the traps (65 Fury) when the rear joint failed. Front half of the driveshaft beat the crap out of my exhaust and put a dent in the floor. Broke the trans at the bell housing and the starter broke off. Rear half was spit out and shot in front of (but missing) the guy in the other lane.NHRA says 13.99 or quicker with slicks, 11.49 or quicker with street tires. I broke a stock driveshaft once in my '65 Coronet going through the traps, mid 12 second car. Tossed half the driveshaft out the back which flew directly over the windshield of my best friend in the other lane. Tailshaft housing disintegrated, output shaft bent about 2", trans case broken at the bell housing area off the motor. First thing I did when I bought my Satellite was order a 3" chrome moly thick wall shaft with 1350 U joints. A loop is mandatory in my opinion. BTW drag radial street tires hook as hard as many slicks.
my baby brothers.....
