Power Steering Conversion
sonny martin
7:17 PM
new albany in
I am putting power steering on my 65 dodge coronet . I have added the double crank pulley and a federal pump with pressure fitting on top ( 1968 rebuilt). I am putting a borgeson gear box . New smaller box with direct fit coupler so I don't have to cut steering column. My question is does anyone know the correct pressure hose to fit the federal pump which uses a o ring on the pressure side. Thanks
Should have used a Saginaw pump, but that's hindsight now. You'll need to have one made at your local shop.
That's an ORB fitting power steering hose and it is best to have one custom made.
If you can't have one made at NAPA, find someone who makes hoses for heavy equipment or industrial machines.
