Finally got me a car...69 Roadrunner...need some stuff
JC Childress
8:35 AM
Big Island,VA
Well, after more searching than I care to think about....I finally got me a car today. It was bought brand new in the county that I'm from and I got it from the original owner. So, its a B5 blue, 383 , automatic, 69 Roadrunner.
After getting it home and getting on the lift....I was sick. The rear frame rails have a little rot back near the rear spring hanger area. Its solid if you go forward about 12 inches from the back bumper. Does anyone sell a partial frame rail that I can splice in ? I want to just cut out the bad part...obviously I'll go a few inches forward of the rot. Also needs a trunk floor. I see trunk floor extensions, and complete trunk floors. If you buy the complete floor, do you still need the extensions ?
Also need a floor pan section but really only rusted a little right where your feet go, on the drivers side. Is there a partial floor pan available also , just for that area of the floor ?
Thanks for any and all help
They all have rust in those areas. The complete trunk does not include extensions. Rear frame rails are available. Relax, bear down, and get er done, it's doable and minor.
Congrats!!
You got one, that is the main thing. The parts are available, and now the work starts!
:xscuseless:
Let's see some pics! We can better assist with you questions if you feed us with lots and lots of pictures!
ya man, make with the pichers!! oh, and congratulations!
You can get all the exact pieces you need. Cut out the trunk and extension, redo the rear frame rails then weld in the trunk pieces. Driver floor can be welded in at any time before or after.
You got a 69 RR,
great !!
Time to call AMD see what panels/sheet-metal they have available
you can always buy a bigger piece
& use just a portion of it if the area is small
happy Moparing
Fix the front & rear window leaks before you fix anything else. They are the source of your floor & trunk problems.
