WTB 1968 Coronet RH Rocker Moulding
JimKueneman
8:30 PM
Sonoita, Az
Feedback: 2 / 0 / 0
Anyone have a good driver quality RH Rocker moulding for a 68 Coronet they are willing to part with? If you don't know which side you have the rounded corner goes to the front of the car and should be on the bottom side toward the ground.
Mine has the LH one on the RH side and probably a Plymouth one on the LH side (no rounding edges, sharp angles on all 4 corners).
Jim
I have an Nos 68 Coronet 69 Charger 500 Rocker molding if you have this style. I think it's LH though cause the screw goes to the back. I would have to check what's left of the wrapper to make sure....
Is 2 door and 4 door the same? I have moldings from a 1968 4 door.
Added photos, note this the the left one that is on the right side so the rounded side should go to the front.
82" long and 3.5" high
Front edge
Rear Edge
I have a pair of these. PM me your email and I will get some pictures over.
D
