Needing Recommendation on 69 Roadrunner Hood Replacement
1BadRM21
1:27 PM
Maryland
Currently have a 69 RR with 440 with cross ram and EDB 650 carbs. Limited to using velocity stacks vice air cleaners due to stock hood clearance issues. Do not want to "cut" my original steel hood. Asking for recommendations on aftermarket hood/hood scoop and air cleaner combinations that would be compatible.
Check out the a12 lift off hood option. I think the scoop on it would entertain your cross ram and make the car look even more nasty than it already does. I did that on my 68 but had also. Gone to the six pack intake and carbs as well.
GetX'd....thanks for the recommendation. After many measurements I was confident this would work. Bought the AAR lift off hood....worked great.
