oldbee
This may be way out there but are you using Bosch relays with no capacitor wired inside the relay? If no capacitor that could be source of rf. They make both kinds of relay with & w/o.
You mentioned "under a full load", so are you saying turning just the headlights off or turning off any device that decreases the load will allow the car to run correctly?The fan is on the main feed of the alt. here's more info I found out tonight.
it is a rf spikes I'm almost sure. It only misfires when under full load fans ,lights and a/c .Checked coil voltage during misfire and voltage stayed 13.34 volts no drop. Turn headlights off runs fine. So I ran wire from battery to coil. started car turned all things on and it ran fine. so now what?
I'm not familiar with HEI distributors at all. Did this issue start at the same time you replaced the ignition? Looking online I noticed that some require an ignition box and some do not. What distributor, brand/model do you have? Do you utilize have an ignition box?
Well I'm totally confused. From full load to turning off just the headlights works, it doesn't sound like RF to me anymore. Your test of running the coil directly off the battery and the car running fine is telling us something. So it likes the voltage/connection from the battery but not from the blue field wire even though you said you had 13.5V at that point. I believe you said you bypassed the ballast resistor. I'd say to try to find another switched 12V source but you have to find one that is not shut down by the momentary start position of the ignition switch. I'm sure someone will know where to find such a source. Also, if that ignition module is mounted on the distributor it will need to have a good ground as shown.
I will look into bulkhead as soon as I can . I will report back.In post #20 you said "So I ran wire from battery to coil. started car turned all things on and it ran fine.". That's a big clue.
