FOR SALE Restored Seatbelts
dart4forte
7:43 PM
Mesa, AZ
Feedback: 4 / 0 / 0
Restored 1965-1974 B Body seat belt set, new webbing, all hardware restored all necessary hardware to completely install your seat belts. Date tags and NOS webbing is available at an additional charge.
$350 for a basic set. A basic set consists of belts for bucket seats or bench, shoulder belts rear bench. A third lap belt set or shoulder belts for the rear bench is available for an extra charge. Hardware such as bolts, mounting plates, date tags etc. are extra. A basic set will have some flaws in the hardware. No core charge is required.
$550 for a show quality set. This set includes everything needed to install in your car. It will include all necessary belts, hardware and date tags. A $150 core charge is required. $250 core charge for 71 belts. If you have a core set it must be complete, be of the same model year and totally free of pits in the chrome and corrosion. Cores must include bolts.
Mesa AZ
If basic set has no hardware how is there flaws are we speaking of the latching parts? Or were the bolts go threw (were you don't see ?)
May be minor pits inside the buckle etc. We do our best to pick out the very best cores. For the most part they are disassembled and worn or broken parts are replaced. The most common problem is the roller inside the buckle. It becomes corroded because the webbing material wraps around. If the chrome doesn't buff out we don't use the parts. Our main emphasis on driver quality belts is functionality.
Ok I'll have a look at my cores see if there's a whole set that is core material for you guys I like near perfect stuff but minor won't hurt as I plan on this being a show/driver so it will be getting used a lot and they will deteriorate eventually
We dont require a core with the driver quality.
