BEST PAINT FOR UNDER BODY?
jluisfelipe
12:21 AM
Miami
Hello, i have to paint the under body of my 1970 Dodge Charger RT. It will be a mild restomod (classic look with good track performances). The whole car is gonna be painted in black. What do you think is my best option?
One friend of mine recommended this product...
Any advice is more than welcome!
The correct way to do it is to paint the underside the same color of the car.Thats how mine was done .code 99 99 Vitiam "c" orange on top and also on the bottom...
OE Correct is not one single color.....
If not going OE correct then one single color matched...
I agree with the prior posting, I just painted my undercarriage with Urethane Single Stage for durability purposes in Hemi Orange V2. The exterior of the car will be V2 base /clear coat, but the under body was done in Urethane. Some purists of numbers matching cars may do a restoration simulating the factory primer dip coat and a little over spray on the rockers and floor pans with color, but since I too am bringing back a non numbers car, I opted for the painted under carriage. To each is there own opinion. Its your car.. make it your own and enjoy it when its done. :)
HR 20
HR 20
More to it than a dip line and a little overspray....Try bare metal areas, grey almost white primer(certain sheetmetal), red oxide primer(exterior body and wheel wells), greenish primer(between inner fender and fender lips), overspray, runs, sags, fisheyes and even trash...
Another factor is how much do you plan on driving it? I would choose the path of least worry depending on usage and want...
please don't use the rustoleum.......and don't let anyone talk you into por15 either
no need to go high dollar, a low end epoxy or single stage urethane would be fine
no one ever looks at the underside unless it's F'ed up, and UV rays won't be an issue
Alright! Rust-oleum seems to be an awful option...
I am not pretending to be purist, I just want the car looks great, so urethane and single color could be a good decision. What do you think? Thanks for your help!
Agree wholeheartedly with spraying single stage urethane on the underside and engine compartment.
Do you recommend me any single stage urethane paint brand? (black)
By the way, engine compartment is already painted (with regular paint, no urethane product). Will I have problems with that? Should I repaint it before I put the engine on?
For your first question, most any name brand paint mfr. PPG, Dupont, Sikkens, RM, BASF, "should be" able to formulate a single stage urethane product, if they are still maintaining a single stage product line. Some Mfrs. do, some don't. The listed companies are all good quality products as long as you stick with the same line of thinner,catalyst,primers etc. I don't recommend cross mixing Mfrs products. Urethanes especially black would benefit from adding top coat clear to the last spray coats of the undercarriage and engine compartment. Urethanes also can be air dried which is what I like best. For your second question, paint problems arise from poor prep. If the surface wasn't sanded properly, de-greased properly, or not primed, the paint will have problems down the road. In addition,..having too much paint sprayed on will cause cracking. There are many gremlins that surface with poor paint prep. I just listed one of them.
The last point I'd like to make is, trust me on this...it will depend on your overall project budget. Purchase the quality of paint you can afford and live with.
To give you an idea of how much top quality Urethane costs, 1 gallon of PPG DCC concept single stage Urethane in V2 was over $600.00. Plus the cost of hardener catalyst, thinner, primer and primer catalyst, mixing cups, sandpaper etc., now your looking close to $1K. I know cause I've just completed my undercarriage, interior floor pans, trunk, and front inner fenders and frame rails 2 weeks ago. It looks gorgeous and the paint flowed out nicely and covered really nice.
I was very happy with the results. I have about a quart of paint left for other parts of the car to spray in the Springtime, so for me buying a gallon is what I had to do. Hope that brings the reality of Urethanes to your inquiries for under body and engine compartment area's. I would save base / clear coat paint systems for the exterior body panels. And don't forget to use a high quality full face respirator when using Urethanes, including a zip up paint suit, gloves, and eye ware even when painting in a home garage or outside.
HR 20
Wow!! Thanks for the explanation Hotrod20. It is very useful. I really appreciate your help.
Would rust-oleum be useful for the floor? I mean, below the carpet. What product would you choose for that? I have heard it is good to reduce external noise. The thing is I already bought fatmat insulation. May be the best is to use regular paint, but car will be noisy, so... what would you do?
Well sounds like you have two different questions. One about paint and the other about noise. Rustoleum can surely be used for the floor pans under carpeting if you have purchased it already. I mean its not seen, and can't hurt if its applied to a properly prepared surface.That will help seal the floor pans from any water or moisture intrusion down the road. Id coat the floor pans, and then install the fat-mat to help with sound dampening. I guess its depends on what your expectation is as far as how much road,engine and exhaust noise is acceptable to you. Me ..? I like a little rumble from camshaft overlap through full exhaust. :)
HR 20
^Werd^
