dvw
I did not coat the crank/rods, but the bearings. My motor has never been dynoed. It has been 9.02@151mph at 3350lbs so it makes somewhere around 900 hp. Power increase when coating/finishing the crank and rods would be proportional to how poor the oil control is in the crankcase. Were they using a deep pan? crank scraper? thin oil? See if the stock, S/S, Comp eliminator racers use this process. That will be the telling tale. I can tell you that even swapping from 20w50 regular oil to 0w30 synthetic gained less than .05 in ET. Gaining 4% power with out going into the basics, cam, heads, intake,compression is very tough, very costly. Lots of HP claims. Lets see how much faster the car goes.Good thing the Eagles crank isn’t coated but it is a finishing process.
You coated the mains and rods?
Main what? I’m missing something.
How much power was/is your build?
