DRIVESHAFT
MADCIMA
7:38 AM
italy ravenna
Hi, guys, I need to know what kind of transmission shaft I need.
my combo is engine 318 gearbox 727 rear end 8 3/4.
if you have a spare or other code to advise me
Thanks in advance
Thanks in advance
I think you will need to let them know a little more info about your car...
The best way is to just measure between the points in diagram B7 the measurement you need it #B6
read the above
you need to specify if you have the large or small ujoint and check to see if both are the same and that each side of each is the same or if one side large one side small let us know
get genuine spicer u-joints with the grease fitting in the cap especially on the small u-joint
the number stamped on the bottom is 2660724 or 2560724. The back tends to shrink, it does not have pinyoke
these are the only information I can have.
and I'm not sure if this belongs to this car, it was disassembled.
I will try to do 2 counts with the table above
