- 11:29 PM
- Jan 14, 2009
- Shoreline, Washington
Thanks guys your awesome!
72Roadrunner GTX thanks yup the red wire with black trace was not only without insulation but frayed and no longer connected to anything but headed towards the fuse box.
It looks like from Threewoods schematic and mine that it provides power to the ignition? This would explain two things.
1. the shorted yellow ignition line I found in the steering column burned out this line.
2. This being the supply to the ignition would explain why I get nothing when I turn the key.
This does beg the question of why does my headlights and horn still work without this line connected? Looking at the scematic it looks like that red-trace line supplies that node (weld splice) 12V from the unswitched VBAT.
Also where is this splice I hear they often fail...???????
The red with trace, Q3-14R*, does not supply the ignition, it supplies the unswitched “BATT” bus in the fuse box. Again, the horn, headlights, and ignition switch are powered from other wires that originate from that same welded splice, that is why the horn and headlights continue to function. The ignition power feed, circuit J1-12R, 12 gauge red wire, does not originate from the fuse box. Do you have voltage on the red wire at the ignition switch Molex connector?
The small yellow wire you found pinched is the ignition lock lamp lead only. With the delay relay removed there was no short on that circuit, and would have blown a fuse if it had been in place, not a factor in, unrelated to your current issues.
The splice is feed from the black 12 gauge wires, charging side of the ammeter, splice is taped up in the dash harness, not sure on the exact location for ’70, but usually between the cluster and the bulkhead connector. Follow the black ammeter wire, you will find it.
