- 12:45 AM
- Jan 14, 2009
- Shoreline, Washington
That is correct, post edited,red must be with black on ignition on too, even has nothing to do with ign system
I would check the yellow wire run from the ignition switch connector to the starter relay for shorts. Disconnect the ignition switch connector, connect the yellow wire back on the starter relay. Take 2amp fused jumper to the ignition switch connector (harness side), jump the red wire to yellow. Should get starter operation without blowing your fuse as you did at the relay. If the fuse blows, you have a short on the yellow wire in the dash harness somewhere that would explain your smoking wires while cranking.
Hi 72RR the schematic has two wires on that side of the fuse. With a buss bar between them it implies that it is indeed the 12V feed side. Why is the red wire so much larger than the red-trace wire? The red wire in the schematic is shown going to the headlight relay. All that remains from the red-trace wire is about 3 inches out of the harness and there is no 12V on it.I would refer you back to post #37 for a detailed description of your burned wire. It was the original unswitched power feed to the fuse box. If you have unswitched power there now, it was likely added/by-passed on another wire somehow or the burned wire is still feeding the fuse box. Replace the wire with a similar sized or larger wire.
Your right 72RR! Thanks!b Looks like the schematic I WAS using is not correct. Now going strictly with mu FSM schematics for the Belvedere! This kills the idea I had on that wite but I will shift away from trying to debug that wire as it will be more evident as I get all the sustems up and running.The FSM diagram is showing only one feed, Q3-14R*, 14 gauge red with trace, as the un-switched (BATT) power feed. Runs from the wire weld splice to the BATT bus. Sounds like the larger red wire has been added. Where does it go to?
Headlight relay? On a Plymouth? No, that would be Charger only. Problem with third party wiring diagrams, not that accurate on details.
I don’t know what a headlight delay is. So I don’t know. But it could explain the wire in question. Because it dives into the harness I can not physically trace it. I do have power on the unswitched fuse bus...Headlight delay relay? Is your car equipped with this option/accessory? Q3-12R would be the power take off for this option, not a power feed for the fuse box buss.
Ok just noticed that the wire on the fuse was spliced with a red only wire. Its actually a red wire with a white trace and indeed is supplying 12V and now correctly coresponds with the schematic as it indicated a red with trace wire. Below is the unknown wire. Pink or violet with a black trace it went as far as the fuse block area and no trace of a connection. And yes Bubba installed the break release upside down lol.Appears the dash harness is prepped for the headlight delay relay option. Never run into it on a 2-door B-body. Higher end option mainly found on C-bodies. Disconnect it (12 gauge red wire) from the fuse box buss, check again for power at the bus, I think you will find your burned wire continues to feed power from the weld splice.
