HT413
Semi Pro Bowler
Need to put more miles on it. Mine took about 200 miles to self learn. Have fun!
Yeah figured as much. Dave I gotta tell ya, the car is FASTER with the EFI. Much more power up in the RPM range than the 750.
Between you and @1967coronet440 I went ahead and pulled the trigger, went a little different direction though...bought the Terminator... Gawd I'm so far off from getting to use it!!!!
I'm glad to see your geting some enjoyment though, it's funny they all say intall in a day, but don't tell you it takes a week to get it tuned lol!
Will a drop base air cleaner fit over the throttle body? They look fat.
Interesthing , veeerry interesting !Well after about 150 miles, what a difference. Car still hunts a little at idle, but boy she runs good.
Some transitions are still a little shaky, stumbles once in a while when accelerating from a coast, especially from engine braking. Transition to idle is a little drawn out sometimes and I think it could use a bit more fuel on cold start.
Crazy how noticeably it’s tuned itself up to this point. From first fire up till now it’s like I’ve taken it to a tuning shop. I figure it’ll iron things out on its own... let’s give it another hundred miles.
Also, finally opened up the rev limit to 6000 from the 5000 I had set at break in. Seems to be breaking up a bit from 5400 on up, so I’ll be taking a couple degrees of timing out. Let’s see how the fitech deals with that.
This guy had some good tips for tuning, I think you may be able to correct your stumble coming off a coast using some of the adjustments he speaks about.Well after about 150 miles, what a difference. Car still hunts a little at idle, but boy she runs good.
I had the same problem with the plug. when I got the new Orings from FiTech the small one was smaller than the one supplied. ended up they installed the wrong Oring from factory.Found the leak. The hyfuel comes with a removable regulator, which they recommend to remove the fitech has its own regulator. Well, the plug they provide was the culprit.
After removing it and replacing the o rings it still leaked, so I compared the plug with the regulator and noticed some dimensional differences. So I decided to go against recommendations and reinstall the regulator.
I guess if the fuel pump reg was set below the reg in the throttle body, I’d get a fuel supply issue, but even at full throttle the AFR was fine so and no leaks so...
