Nacho-RT74
- 11:45 PM
- Oct 8, 2012
- Valencia, España
small red ones are for the key in buzzer which is an acc on the car not part of the ign system... must be removed from original switch plug and added into the new ign switch plug ( no particular order ). They are red into column but black on dash harness ( at least on mine ).
Black on ign switch... I never have known what is for on ign switch, but sure you don't need it. New ign switch should get instructions sheet... Once I got to save a pic of the instructions sheet of that ign switch setup on the web but is incomplete. It states every setup existant and what is needed to make on that replacement switch to match it with your car
I think you can cut it from the very end of the wire at ign switch end and rmov the full wire or simply remove and isolate the terminal from plug ( you choose ) and replace that cavity on plug with your existant orange wire setup for the shifter lettering.
