FOR SALE 1969 Coronet 440 Four Door
Hemihead2
2:30 AM
Pa
Feedback: 3 / 0 / 0
I'm offering up an incredibly nice and super solid 1969 Coronet 440 four door. This car has no rot anywhere and only minimal surface rust. It is a low mileage (perhaps original paint) car that was apparently well taken care of. The body and chassis is solid from front to back. However, I did find two areas of concern- 1. The pass side front floor has a small area of rust-through that occurred where some water pooled (half dollar size). Two- There is rust up under the inner trunk lid lip (cannot be seen with the trunk closed.)
I have carefully looked over the hood, core support, fenders (some dents and surface rust but very solid), inner fenders, fire wall, front/rear frame rails, rockers, trunk floor, extensions, wheel houses, tail panel, front/rear cross members, front and rear floors (except where noted); they are all solid. If you are a true OEM, spotweld cutting, resto man this is your car. If repops are fine then its probably no big deal to you.
I have decided that it is missing too many pieces for me to try and make a driver out of it. It has drum brakes up front and an 8 1/4" rear in the back.
It would be foolish of me to part the car out if someone truly has a 69 Coronet/ Super Bee and needed all the associated body panels and frame rails that interchange. If no takers of the whole I may part it out; but I really don't want to. Asking $2,100 at this time. A Bill of Sale will be provided. Please PM me if interested. Thank You! Located in Pa 16602
image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
I’d be interested in the bare shell with front suspension if you do part it out
Not much there far as the interior goes: Front and rear seats, door panels, A-pillar trim are about it. Included some other body shots as well.
if parting trunk floor pan ?
Willing to sell the hood release rod, that goes from the lever to the latch?? Thanks!
Dadsbee.....I most likely have that should have asked
