66383
DETAILS MATTER!
- 12:02 PM
- Jan 19, 2018
- calvert city, ky
difference??
489 pinion is tapered and considered the strongest, correct?Biggest (and probably the only) difference is the size of the pinion shaft. The 741 is the smallest of the three and the 742 is the largest. The 489 sits in the middle.
In the tech archives on Moparts there's a comparison photo of all the popular rear ends including the Dana, GM 12 bolt and the 9" Ford.
And have you ever seen a 741 with a broken pinion shaft? Very rare.....and the splines where the yoke fits are all the same size with only the difference being fine and course.
Read below! A buddy and I ran a 4 speed roadrunner in the Super Street wars (10.90 index) in the early 80's and before we even got the car into the SS ranks, we started shaving ring gear teeth with the 8 3/4. Pinion deflection or....??? It didn't matter what rear we used as all of them did it. We used the 89 figuring the 42 wasn't strong enough but it failed just as fast. Lousy setup? Who knows as we weren't doing the setups at that time but we swapped to a Dana and all that went away. It was about that time when we started doing our own setups.....Hey Cranky, can you elaborate on the fine/coarse splines on the pinion/yoke? I just learned that there was 2 different splines about a month ago. Is one considered stronger? (coarse?) What cars got fine? Which ones got coarse? Any other related information we should know?
THANK YOU!
Cool beans! I ran across a similar site stating the differences but couldn't find it. Didn't even think about looking on Cass's site. Thanks!Cass has some good info here: Doctor Diff
TLDR...it's not as big a difference as many make it out to be.
741 is 1-5/8" correct on the others.I thought the 489 was the largest at 1-7/8IN, 742 at 1-3/4 and 741 being the smallest at 1-3/8?
My 65 Satellite 383HP 4-spd had a 741 SGmany 383 cars came with the 741 behind them, I'm sure the factory would have not used them if they thought they would not hold up the the torque of the 383 motor.
So are parts available to rebuild a 741 Case 3:91 Suregrip that I pulled out of a van many moons ago ?
Resides in my 71 Bee now for the last 25 years
Factory 489 Case 3:23 Suregrip is long gone
489 crush sleve
741-2 shimms
489 cone SG
741-2 clutch SG
