451Mopar
I did not run the numbers, but the compression and cam timing is close to what I have in the 505" stroker.
When I was first working on the tuneup I did hear some pinging, but it now runs fine on pump.
Keeping the air inlet temps reasonable really helps, compared to sucking in hot under hood air. I also took the 195 degree thermostat out and went with a 180 degree thermostat.
