Gear Surprise in Rear End
FlagCraig
4:10 PM
Tennessee
Took rear end out of 67 GTX during re-build yesterday and to my surprise they were 3:55 and not 3:23. See pic.
This leads me to ask the question was 3:23 standard in GTX with automatic and 3:55 an option?
Also, any idea what the white paint means.....093? (build sheet #?)
I do not have the build sheet and I am confident the rear end is original to the car.
Thanks.
If you have a fender tag what are the numbers under the AX? A 6 under the A would be 3.55. An 8 under the X would be a suregrip. A 4 under the A would be 3.23 originally.
Under the A is a 4 and Under the X is an 8. So based on this it looks like the gears were changed at some point.
Forgot to really answer original question, 3.23 was an almost universal ratio back then for everything. Anything else an option or part of an option.
Thanks.
i may be wrong but i do not think that is the original rear end for your 67 GTX ,, from the picture it looks to be a sure grip unit ( cone/spring type ) not available till 1969 ,,,,should have been a Power Lock clutch type unit .
You are correct young man. The date reads 11/12/69. Good call. Still its a very good looking rear end. And it should handle the 440 re-build just fine.
What does this number mean on the outer casing of rear end?
See Pic. Thanks. 2881489
It's a tapered pinion which uses a crush sleeve. They came out starting in 68. And right now would be a good time to pull out the carrier and take the cone type Sure Grip apart and check the clearances on the cones.
