Sonny
I’ve had this issue for a month now since getting new carb. First sign: I went to accelerate over an inclined road (train overpass) and all of a sudden air fuel gauge goes way lean, car is stumbling, I’m pedaling it the whole way up, levels out and clears up. So I thought-fuel delivery issue- added a 3/8” tee, a second 3/8” line and made the Edelbrock avs2 650 a dual feed Carb. Problem happens again on flat road and I notice the fuel filter is bone dry. Took 30 min to restart and prime line. Next logical assumption- failing fuel pump, so I buy and install a new edelbrock fuel pump. Happened again today, took 30 minutes to reprime the system again. Same thing, no line pressure or fuel in filter. So I have the following new stuff:
Fuel pump
Avs2 carb
Rpm air gap intake
ignition system
fuel hose and filter
Fuel tank and sender
Original stuff:
5/16” fuel lines from pump to tank
Original tank vents
Also thought fuel gauge was lying, it wasn’t. Happens at 1/4 tank and at full.
Here is fuel line chart:
5/16” sender line in tank
5/16” fuel hard line (old)
5/16” adapter on “in” side of pump
3/8” pump outlet and 3/8” all the way to carb. It’s been a rough car month. Open for any suggestions.
Fuel pump
Avs2 carb
Rpm air gap intake
ignition system
Original stuff:
Original tank vents
