Driver side is finished, took me 2 hours.  No real issues, the upper ball joint takes some work but it came out fine.  I will say test fit the outer taper bearing on the spindle as mine would not go on because of a burr.
Out with the old.  Jacked up, jack stands.  I moved the jack stand under the lower control arm to keep it up while I R&R'd the spindle/lower ball joint.  Another issue was lining up the cotter pin holes with the castle nuts but I eventually got them aligned and installed.
New spindle installed...
Then I assembled the rotor, bearings and seal.  I packed the bearings, layed it in the rotor and set the seal.  The rotors come with the races installed...
Then I attached the caliper bracket using anti seize...
Splash shield (Bill told me I could delete this to aid in cooling so it is optional).
Next I installed the rotor assembly and filled the cavity with grease, installed the outer bearing, washer, nut, nut retainer, cotter pin and dust cap...
Caliper gets put into place after modifying the outer brake pads (bend over the tabs for a tight fit to caliper) and then the retainers and brake line.  Now onto the next side...
